web map asking for login information
1167
02-04-2020 10:55 PM
SwadeshSharma
Recently I created advanced map using Sentinel-2. It shows fire on specific past date but It is not publicly access currently it is auto popup login information so is it possible to view without login?
webmap id: 79e1f429538b41698d97fc819dc412fe
URL: http://incaendiuminitiative.com/demo
Attached screenshot
Tags (1)
JacobWatson1
Make sure all the items that you are trying to show are not a premium content of some kind. If all the items are your own, I would check the sharing setting to make sure everything is set for public.
by Anonymous User
Not applicable
Hi Swadesh,
I checked your services that the app is pulling and those don't seem to be a problem. Have you enabled subscriber content to be used in Web apps/Story maps?
Using subscriber content in Web Apps and Story Maps
If it's still prompting a log in.. Can you try the following workaround?
  1. Add the subscriber content via URL to the user Content page
  2. Embed credentials
  3. Use that in the web map to start with
