I am learning more about the use of ArcGIS Online. I am practicing using the tools to Create Watershed and Trace Downstream. I use a map pin and pick a place in Utah (topographic basemap), go to analysis and create watershed. It runs the process but the adjusted points and watershed are drawn in eastern Africa. I picked a spot in Ohio and it completed the process as it should. I tried various US states and some watersheds ended up in Africa, while some were in the correct spot. Any idea what I might be doing wrong? I think it is strange that some states work correctly, but others don't. I attached a screenshot.
Thanks in advance!
Hi AASTGIS,
From your description, I believe that you were using the draw points functionality to specify a point, is that correct? Could you try with a persistent layer, i.e. a point feature layer that you have added to your contents? I would just like to understand better what could be causing this issue.Thank you very much,
