Visibly display assets based upon extent
839
08-09-2022 10:59 AM
JimmyXin
Is there a feature that displays all of the visible assets within an extent in a table? For instance, if I have my map appear within a neighborhood extent, I wish to see all of the water valves in that area appear on a table. Thank you.
RhettZufelt
MVP Notable Contributor
The Attribute table widget in the Old Web Apps has a Filter by map extent option:
Experience builder will also let you filter most the widgets by map extent, including the table widget.
R_
