Visibility Ratio calculated by Skyline Graph
991
12-09-2019 08:21 AM
SatoshiHirabayashi
When you run the Skyline Graph tool in 3D Analyst Tools the visibility ratio is displayed in the Results window. When you run the same tool in a stand-alone Python script is there any way to obtain the visibility ratio in the Python script?
KhalidDuri1
Hi Satoshi, we have an enhancement request to provide that information in the return of the tool's execution in Python. For now, you can use string manipulation to extract the value from the result of arcpy.GetMessages():
float(arcpy.GetMessages().split('degrees is ')[1].split('.\n')[0])
by Anonymous User
Not applicable
ArcGIS Pro3D
KhalidDuri1
