Hello
So I created a multipatch feature class from a 3d model in Arc Pro. To bring it to Arcgis online, I then shared it as a layer package. Is there a way to view and project this data online, or is that something in the works? Also if not, is there a way to convert the model from a multipatch file into its various parts?
Solved! Go to Solution.
So for viewing multipatch data in ArcGIS Online as a hosted service, first you will need to use Pro 1.3 to create a scene layer package. To do this you will use the GP tool "Create Scene Layer Package" which will take your multipatch data and generate the scene layer package which you will then upload to ArcGIS Online to create a hosted scene layer which can be used in the scene viewer.
Let me know if this helps you out
Russ
Russ
