Vertical Offset Scene Layer from Revit model in a webscene not available (anymore)
1573
11-28-2022 03:11 AM
Stefan_Thorn
As far as I know last year it was possible to assign an offset to a scene layer. this scene layer
workflow:
1. revit model --> scene layer package
2. publish to AGOL and add to a global scene
3. add offset to the scene layer because a revit model has not always assigned all the coordinate system properties
A workaround could be to assign a cartographic offset in ArcGIS Pro and then create the scene layer package but the possibility to assign a cartographic offset for a Revit model is greyed out:
RussRoberts
Esri Notable Contributor
This is not supported on BIM layers yet. You will find this property under other scene layers like 3D Object that support being styled in Scene Viewer.
RussRoberts
Stefan_Thorn
Thanks @RussRoberts, you are right. I was confused, i went back in my history projects. I had converted the BIM file to a geodatabase and then published it to AGOL. This will allow to add an offset to a layer.
