Using unique symbology removes feature template functionality?
765
04-05-2019 12:09 PM
ShelbyZemken1
I'm trying to symbolize points by a integer value using unique symbols, but I also need to create data using feature templates on the same layer. If I try to symbolize by the integer value I get a pop-up that says 'this may change the type of objects you can create', and it doesn't allow the use of the templates I created. Why cant you have both uniquely symbolized points and feature templates?
