Using SQL in an Arcade GroupBy expression
2345
6
09-19-2024 01:25 AM
JasonBatory
Can anyone confirm whether expressions like this should work, or if my syntax is just wrong?
In my Arcade groupBy function I want to use SQL in the expression, like this:
var fs = FeatureSetByPortalItem(
  Portal("https://www.arcgis.com"),
  "6200db0b80de4341ae8ee2b62d606e67",
  0,
  false
//For each building FeatureCode
//Count how many buildings with each FloorCount
return GroupBy(fs, 'FEATURECODE',
[{name: 'Floors_0', expression: 'FLOORCOUNT = 0', statistic: 'Count'},
{name: 'Floors_1', expression: 'FLOORCOUNT = 1', statistic: 'Count'},
{name: 'Floors_2', expression: 'FLOORCOUNT = 2', statistic: 'Count'},])
 This returns an error:
Test execution error: Unknown Error. Verify test data.
 I've tried various different syntax for the 'FLOORCOUNT = 0' statement with the same results.
jcarlson
In GroupBy, the "expression" key is specifically looking for valid SQL.
@JasonBatoryin your series of expressions, you're treating the "expression" like it's a filter. In GroupBy, it's going to attempt to return the statistic from the expression, and you can't really count whether or not the floorcount is equal to a value.
To use @CodyPatterson 's idea, but in SQL, you can use CASE:
"CASE WHEN FLOORCOUNT = 0 THEN 1 ELSE 0 END"
Use that with the statistic "SUM", and you'll get the number of records with that particular floor count value.
- Josh Carlson
Kendall County GIS
CodyPatterson
MVP Regular Contributor
Hey @JasonBatory
Could you give this here a shot? You may want to use Iif in terms of the expression:
  0,
  false
[{name: 'Floors_0', expression: IIf($feature.FLOORCOUNT == 0, 1, 0), statistic: 'Sum'},
{name: 'Floors_1', expression: IIf($feature.FLOORCOUNT == 1, 1, 0), statistic: 'Sum'},
{name: 'Floors_2', expression: IIf($feature.FLOORCOUNT == 2, 1, 0), statistic: 'Sum'}])
 The 0, 1, 0 in the first one, is the values of the condition, true value, and false value, so if it is 0 it will return true, otherwise false.
Let me know if this helps out!
Cody
jcarlson
- Josh Carlson
Kendall County GIS
JasonBatory
Ok, this makes sense now. I also tried "WHERE FLOORCOUNT = 0" with count statistic, but I see this should be treated more like a decode situation using the sum statistic.
Thanks for your help Josh, and Cody.
JasonBatory
Follow up question, is there any way to add a "total" row at the bottom displaying the total of each of the columns "Floors_0", "Floors_1", etc?
jcarlson
Not really. The number of rows in the output are based on the unique values in your second parameter, 'FLOORCOUNT'. There's probably some way to do a second GroupBy and merge it with the first, but it's probably not worth the trouble.
If you're bringing this into a Dashboard, there are lots of widgets you could use to display the totals of each of those columns. Is there a reason you want the total as a separate row in the table itself?
- Josh Carlson
Kendall County GIS
JasonBatory
Yeah this is in a Dashboard, I was basically hoping to just emulate a pivot table, not a big deal.
I guess I can just rethink the design and present those totals in another way.
Thanks again.
