Using rest for Feature Layer
6785
07-04-2024 01:38 AM
StephenHall3
I am new to arcgis and trying to setup oauth to access a feature layer.
My assumption is that I needed to create an application with oauth credentials and (on successful authorisation) a redirect url to the feature layer (where I would pass the token) but I get "you do not have permissions...." message (GWM_0003).
Could someone offer some pointers to achieving the objective?
Thanks
Tags (3)
StephenHall3
Success.
For anyone trying to figure this out (because I could not find any clear examples of how to implement this from beginning to end) here is how it was done.
1. Create a Feature Layer which will contain the database table (columns and rows).
2. Create an Application which will contain a Client ID , Client Secret and a Redirect URL (which will be the url of the Feature Layer) .
3. Using Postman you will enter the URL of the Application, passing in the params client_id, client_secret and grant_type
4. a Token will be returned
5. Using Postman you will enter the URL of the Feature Layer similar to the following:
https://<domain>/<context>/rest/services/<Feature  Layer Name>/FeatureServer/<Dataset/Table Name>/query? along with the following parameters:
f = json, token=[token val you prev received], address=[post code/zip/full address etc], outFields=*,where=[query string ie postcode like 'EH3 4QW']
This will return a json file containing all the properties and values relative to the query
Georgios-NektariosTselos
Hello @StephenHall3  the only thing you have to do for the "permissions message"  is to differentiate the option when you share it from owner to public or to the organization you belong  to,  so that everyone has access. So you need to generate an access token,  the following links will help you  :https://developers.arcgis.com/rest/users-groups-and-items/generate-token/
https://developers.arcgis.com/documentation/security-and-authentication/user-authentication/oauth-cr...
Kind Regards
Georgios-Nektarios Tselos
StephenHall3
I think I am one step closer.
I am now retrieving the feature service settings/structure.
The first screen capture shows the token being passed to the Feature Layer and returning  various settings.
The 2nd screen capture is the table for the Feature Layer.
I'm assuming there is something I need to add to the url that ends "CAG_MONTHLY_RESIDENTIAL" to retrieve data from the table.
Yes,   i suggest to check both of  these links  and i think you will solve your issue
https://developers.arcgis.com/rest/users-groups-and-items/token/
https://developers.arcgis.com/rest/users-groups-and-items/root/
Kind Regards
StephenHall3
Success.
