Using Arcade to Set Up Clean Schedule
1552
11-13-2019 03:29 PM
MagdalenaMartinez
I am trying to set up a collector app for infrastructure cleaning schedules. I have it set up to automatically add a date when a new point is added representing a cleaned line. Now I am trying to set up an arcade script that will take this last cleaned date and calculate the next cleaning date, then use that to symbolize lines now needing to be cleaned.
There are several cleaning schedule categories (1 month, 3 months, 2 years, etc), so the script would need to look at the cleaning schedule field, and then calculate the new cleaning date accordingly. I'm assuming the best workflow for this would be to use arcade functions in order to do;
   -  select group by cleaning schedule
      - calculate next clean date by taking last clean date + clean schedule
       - set status to "clean required" when new clean date is reached
I know to use the DateAdd function to calculate the new date, but I am unsure how to link selecting the date field by clean schedule as I am new to arcade. Thanks in advance for any advice on the subject.
by Anonymous User
Not applicable
Hi Magdalena Martinez‌,
I think you would want to use an if/else statement to find features with a specific cleaning schedule. This might look something like this:
//set global variables
var Schedule = $feature.Schedule
var DateField = $feature.EditDate
var currentDay = today()
//begin conditional statements
if (Schedule == 'One Month') {
Var MonthPickup = DateAdd(DateField, 1, 'months')
var MonthDifference = DateDiff(MonthPickup, currentDay, 'days')
Var MonthDisplay = iif (MonthDifference > 0, 'No Clean Required','Clean Required');
return MonthDisplay
else if (Schedule == "Three Months") {
Var ThreeMonthPickup = DateAdd(DateField, 2 , 'months')
var ThreeMonthDifference = DateDiff(ThreeMonthPickup, currentDay, 'days')
Var ThreeMonthDisplay = iif (ThreeMonthDifference > 0, 'No Clean Required','Clean Required');
return ThreeMonthDisplay
else if (Schedule == "Two Years") {
Var TwoYearPickup = DateAdd(DateField, 2 , 'years')
var TwoYearDifference = DateDiff(TwoYearPickup, currentDay, 'days')
Var TwoYearDisplay = iif (TwoYearDifference > 0, 'No Clean Required','Clean Required');
return TwoYearDisplay
else {
return "No Data Available"
There is also an ArcGIS Solution Template with a much more sophisticated pick-up schedule Arcade script that you might be interested in: My Trash Services | ArcGIS Solutions for Local Government
Hope this helps ~
-Peter
XanderBakker
Esri Esteemed Contributor
Hi mmartinez_cityofarcata ,
I have published a couple of documents related to this (unfortunately in Spanish, but you should be able to use the URL in Google Translate and get a translated page):
A live sample from a client can be found here:
https://emvarias.maps.arcgis.com/apps/Styler/index.html?appid=553c4997f2ac4dbaa04eb044a7572732
If you have any questions, I'll be happy to help you.
