Hello!!
I have been looking all over Esri Community and I cannot figure out how to correctly use Arcade to form a rating system!
For some background information on what I am trying to do: I am an intern who monitors any and all pedestrian features. I take measurements such as slope, length width, gap size, signal timing, etc. to ensure that the features are ADA compliant. There is a rating system in place to help us determine the severity of the damage of the feature, if there is any at all. This rating system is an excel sheet that we manually use and we compare it to the data collected to rate the feature.
What I want to do is automate this process. I have successfully created this rating system, however, the expression I came up with is very very long and tedious to add on to. I have limited knowledge of Arcade so any help would be much appreciated!
var cs = When($feature["cross_slope"]>2 && $feature["cross_slope"]<2.5, 8, when($feature["cross_slope"]>=2.5 && $feature["cross_slope"]<3, 7, when($feature["cross_slope"]>=3 && $feature["cross_slope"]<4, 6, when($feature["cross_slope"]>=4 && $feature["cross_slope"]<5, 5, when($feature["cross_slope"]>=5 && $feature["cross_slope"]<6, 4, when($feature["cross_slope"]>=6 && $feature["cross_slope"]<7, 3, when($feature["cross_slope"]>=7 && $feature["cross_slope"]<1000, 2, 10)))))))
var gw = when($feature["gap_width"]=='rating6gap', 6, when($feature["gap_width"]=='rating3gap', 3, when($feature["gap_width"]=='rating2gap', 2, 10)))
var lw = when($feature["lip_width"]=='rating8lip', 8, when($feature["lip_width"]=='rating6lip', 6, when($feature["lip_width"]=='rating3lip', 3, 10)))
var pa = when($feature["passing_area"]=='no', 5, 10)
var ras = when($feature["road_slope"]>$feature["running_slope"] && 5<$feature["running_slope"]<11, 9, when($feature["road_slope"]>$feature["running_slope"]>$feature["running_slope"] && 11<=$feature["running_slope"]<100, 8, 10))
var rw = when($feature["route_width"]>35 && $feature["route_width"]<36, 7, when($feature["route_width"]>32 && $feature["route_width"]<=35, 5, when($feature["route_width"]>28 && $feature["route_width"]<=32, 4, when($feature["route_width"]>24 && $feature["route_width"]<=28, 3, when($feature["route_width"]>0 && $feature["route_width"]<=24, 2, 10)))))
var rs = when($feature["running_slope"]>5 && $feature["running_slope"]<6, 8, when($feature["running_slope"]>=6 && $feature["running_slope"]<7, 7, when($feature["running_slope"]>=7 && $feature["running_slope"]<8, 6, when($feature["running_slope"]>=8 && $feature["running_slope"]<9, 5, when($feature["running_slope"]>=9 && $feature["running_slope"]<10, 4, when($feature["running_slope"]>=10 && $feature["running_slope"]<11, 3, when($feature["running_slope"]>=11 && $feature["running_slope"]<100000, 2, 10)))))))
var sub = when(cs == rs && cs != 10 && rs != 10, cs-1, when(cs == rw && rw != 10, rw-1, when(cs == lw && lw != 10, lw-1, when(cs == gw && gw !=10, gw-1, when(cs == pa && pa != 10, pa-1, when(rs == rw && rw != 10, rw-1, when(rs == lw && lw != 10, lw-1, when(rs == gw && gw != 10, gw-1, when(rs == pa && pa != 10, pa-1, when(rw == lw && lw !=10, lw-1, when(rw == gw && gw != 10, gw-1, when(rw == pa && pa != 10, pa-1, when(lw == gw && gw != 10, gw-1, when(lw == pa && pa != 10, pa-1, when(gw ==pa && pa != 10, pa-1, 10)))))))))))))))
var total = min(cs, gw, lw, pa, rw, rs, sub)
iif(total == 10, 'Yes', 'No')
