Using Arcade to format date for feature?
2610
03-06-2025 10:36 AM
BaileyDeSimone
Hello,
I have a feature (Incorporation_Date) that, in ArcGIS pro, I set to format 'Month D, YYYY' like the other date columns in my dataset. There are only two map points with this feature, so I use the following expression:
if (IsEmpty($feature.Incorporation_Date)) {
  return null;
  else {"Incorporated on " + ($feature.Incorporation_Date) + " (" + $feature.Incorporation_Citation + ")"}
However, the expression returns the date formatted as YYYY-MM-DD 00:00:00. I attempted to add Text(DateOnly before) the feature to remove the time section, but would like to know how to re-format the date to Month D, YYYY.
Thank you!
CodyPatterson
MVP Regular Contributor
Hey @BaileyDeSimone
From what I'm seeing you're pretty close! Give this a shot here:
  return null;
} else {
  return "Incorporated on " + Text($feature.Incorporation_Date, "MMMM D, YYYY") + " (" + $feature.Incorporation_Citation + ")";
This uses the same Text feature, but assigns the format of the MMMM D YYYY, I think MMMM is the right format for this case!
Cody
RPGIS
by MVP Regular Contributor
@CodyPatterson has the right method but I am simply putting this one out there to show a simpler way of writing the same code.
// Option A
var D = $feature.Incorporation_Date
iif( !IsEmpty( D ) , "Incorporated on " + Text(D, "MMMM D, YYYY") + " (" + $feature.Incorporation_Citation + ")" , Null )
// Option B
var N = Null
if( !IsEmpty( $feature.Incorporation_Date ) ){ N = "Incorporated on " + Text($feature.Incorporation_Date, "MMMM D, YYYY") + " (" + $feature.Incorporation_Citation + ")" }
return N
