User Webhooks in ArcGIS Portal
1143
11-07-2019 07:12 AM
DarrylHilton
I am trying to build some webhooks using Portal. I have created a couple of basic ones set to send all events to Microsoft flow, this in turn is adding the raw data sent to a row of a spreadsheet. This side is all working fine.
However when I try and set specific trigger events (at the moment I am most interested in when users sign in and out) I hit issues. It will allow we to set the "Update the events you would like to trigger this webhook" to /users, but this does not seem to be triggering when a user sign in or  sign out. If I specify this for one user as it says I can do here:
ie /users/*myusername*/signIn it reports:
Unable to create or update webhook.Invalid URL or event has been specified for this webhook with name or id 'Users Webhook 2'
The same occurs whatever I put in the place of the username, and whether the user is a AD user or a portal user.
Am i misinterpreting what I am supposed to be able to do with these webhooks?
Thanjs
