User token privileges
1520
05-17-2023 07:46 AM
infoklicconverter
Hi there,
Is it possible to have create a custom role in which the user doen not have the privilege to create a token via REST?
If that is the case how can I test for that, using the sef or username REST API endpoint?
Itay
TonyContreras_Frisco_TX
I don't think this is possible, since the sign-in process uses the generate token operation in the background to authenticate the user. If a user couldn't generate a token, it would not be able to sign in. Here are the Privileges that can be assigned to custom roles in ArcGIS Online.
infoklicconverter
That makes sense (just wanted to verify it) and I take it that this also applies to sing in with oauth2 + PKCE, right?
I would think so, but I can't say for sure.
infoklicconverter
Well thanks anyway 👍
