Use Map Service as Base Layer?
1737
06-21-2012 12:11 AM
MatthiasHahn
I uploaded a server definition from ArcMap10.1 final to AGO and created the cache.
Now I got a Map Service that perfectly works in any map.
It is possible to use such a Map Service as a Base Layer?
MikeMinami
Esri Notable Contributor
Yes, when you add the layer to the web map, you can choose to "use as basemap".
If you're adding from the Add>Search for layers option, you need to click on the layer name in the add panel to see the option to use as basemap. If you use the Add> layer from web option, and enter a URL, then you'll see a checkbox to set the layer as the basemap.
Mike
MatthiasHahn
Ah, I see.
But this is only possible in the ArcGIS.com Viewer, not in the ArcGIS Explorer, right?
MikeMinami
The workflow for setting the basemap in Explorer Online is slightly different. When you create a new map, choose the "advanced" option to set a custom basemap.
Mike
