URL query parameter requirements
3980
05-12-2020 02:16 PM
JeffThomasILM
I have set up a web map and app and created a feature service for parcels so that I can perform parcel queries via URL parameter. My question is whether it's necessary to use a feature service to get URL query parameters working. I'd rather not create and use feature services when map services would suffice, but is this an illogical preference?
I have a queryable map image service for parcels and I set up the web map/app (hosted on AGO) to make the parcels service/layer (hosted on our Portal) searchable.
I am thus able to perform searches via the app's search field. But the map service-based parcel layer does not show up in the layer list of the app's Custom URL Parameter configuration, so I can't perform parcel queries via URL parameter.
If I add a feature service-based parcel layer, it does show up and I have successfully performed queries via URL parameter.
I've scanned GeoNet and read a few different pages of Esri documentation about how URL parameter feature queries should work but I haven't found an explicit statement about whether it requires a feature service or if I simply haven't configured my map image service properly. Please advise. Thanks!
Configure feature search—ArcGIS Online Help | Documentation
Use URL parameters to modify maps—ArcGIS Online Help | Documentation
Use URL parameters—Web AppBuilder for ArcGIS | Documentation
Using URL Parameters In Web Apps—ArcGIS Blog
