Upload File Geodatabase?
4552
09-06-2013 04:34 AM
GregYetman
The documentation states that you can upload a zipped File Geodatabase to AGOL:
http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q0000000m000000
However, when I try and do so from the Add Content dialog (from "My Content") it will not recognize the file, and File Geodatabase is not an option in the dialog (see image).
[ATTACH=CONFIG]27262[/ATTACH]
Is the documentation incorrect or is there another way to add a file Geodatabase?
TIA,
Greg
MikeMinami
Esri Notable Contributor
This is a bug. We'll get it fixed for our next update by the end of the month.
Mike
GregYetman
A colleague provided a workaround: when uploading the .zip, choosing Desktop Application Template or Map Template as the type will upload the file. Others types may work as well (Shapefile does not). Of course, the item type will be listed incorrectly on ArcGIS Online but the file Geodatabase will be available for download.
I suspect that this may be as simple as a problem with the upload file dialog.
cheers,
MikeMinami
Mike
GregYetman
Thanks Mike, good to know.
Greg
