Hi all,
I have a group of styles which I shared as a custom Utility.style to my ArcGIS Online account. I want to update this group with more utility styles and was wondering if there was a way to add to the existing Utility.style without overwriting the whole style
You will be using ArcGIS Pro to share a new web style that will overwrite the existing one. There currently isn't an update workflow for a web style.
When I share a new web style with the same parameters and name as the previous one, I don't get prompted to overwrite it. It just creates a new web style. Using ArcGIS Pro 3.3.1. Thoughts?
I figured out the issue. The folder that contained the web styles was named "Map symbols, graphics, logos". It appears that ArcGIS Pro is unable to find an existing item if a "," is present in the folder name in ArcGIS Online. Once I renamed the folder without commas, I was prompted if I wanted to overwrite the existing web style.
Awesome to hear you were able to find a work around to the issue, I will pass this along to the sharing team.
