Updating hosted Feature Layer utilizing Python
978
07-19-2023 09:27 AM
Labels (2)
JackieFisher
I've got a Python program that has been running continuously for the past 16-18 months that updates a Hosted Feature Layer within our AGOL account.
The final "write" portion of the code is
data_hold_csv = 'C:\\USGS Live\\HCT - CU\\Clients\\D4_5_Current_Rsvr_Data.csv'#Working file for filter loop
src=data_hold_csv
dst = data_omid
#dst1 = D4_D5_Crrnt_working
copyfile(src, dst)
#copyfile(src, dst1)
gis = GIS("https://www.arcgis.com", "user", "password")
print("We're in ...")
search_results = gis.content.search('title: D4-5_Current_Rsvr_Data', 'Feature Layer')
print("Found what we need ... ")
usgs_fs_item = search_results[0]
usgs_fs_item
print("Past the item ... ")
USGS_flayer_collection = FeatureLayerCollection.fromitem(usgs_fs_item)
print("Getting ready to overwrite ... ")
USGS_flayer_collection.manager.overwrite(data_hold)
print("1.5 - Feature Layer D4-5_Current_Rsvr_Data has been updated for ",client)
print("")
As of 7/14, I began getting the following error:
Selected site raw data has been extracted for rwpc
We're in ...
Past the item ...
File "C:\USGS Live\HCT - CU\Live_USGS_220020.py", line 497, in <module>
USGS_flayer_collection.manager.overwrite(data_hold_csv)
File "C:\Users\Owner\AppData\Local\Programs\Python\Python37-32\lib\site-packages\arcgis\features\managers.py", line 1169, in overwrite
published_item = related_data_item.publish(publish_parameters, overwrite=True)
File "C:\Users\Owner\AppData\Local\Programs\Python\Python37-32\lib\site-packages\arcgis\gis\__init__.py", line 6852, in publish
serviceitem_id = self._check_publish_status(ret, folder)
File "C:\Users\Owner\AppData\Local\Programs\Python\Python37-32\lib\site-packages\arcgis\gis\__init__.py", line 7089, in _check_publish_status
raise Exception("Job failed.")
Exception: Job failed.
What has changed, and how do I work around it?  Thanks!
David_McRitchie
If the script has not changed then it could be the data that is causing issue. I would check that the schema to your CSV input is still the same and that the Hosted Feature Layer still exists and can be viewed/edited.
Hope that helps!
David
Esri UK -Technical Support Analyst
