Unable to Query Public Layer
1629
04-04-2025 09:57 AM
jvarasanz
Good morning.
I have a hosted feature layer and a corresponding view that I intend to share with the public. However, when shared publicly, neither the layer nor the view displays pop-ups, nor can they be queried through the REST endpoint.
Error below (only if shared to the Public):
API calls quota exceeded (7550 request units)! maximum allowed request units (6000) per Minute. Retry after 60 sec.
Could you please advise on how to resolve this issue?
Javier
thesweenis
Can you share the URL for the HFL and the HFLV you can share?  I'd review it and let you know what I see.
jvarasanz
ChristopherCounsell
MVP Frequent Contributor
Your org is exceeding its usage threshold. I've explained this already here:
https://community.esri.com/t5/arcgis-survey123-questions/pulldata-layer-function-not-working-for-pub...
You should be reviewing your organisation and workflows or contacting tech support.
jvarasanz
Thanks Christopher,
We are still confused how a query is successful when I don't share publicly, but not when it is shared, which is when it is consistently failing. Additionally, I am testing in Survey123 Connect by pulling the json string from the layer once I hit the map. Why would that create a spike?
Any other automated processes or tasks are successfully running.
I hope this helps. Just in case we are at 11% of our storage capacity.
Thanks again.
ChristopherCounsell
Can you share the xlsform?
Storage capacity is not relevant.
If you go to the layer item details > usage, is the a large amount of usage (requests) on the item? Does it spike when you share publicly?
What I am saying is that that error message is indicating the number of requests made to your org is exceeding the threshold. Why this is happening is yet to be identified, but that's the response from the server. It could be that something is hammering your publicly accessible layer. Or coincidence. Or the pulldata expression itself, but that's not normal.
