unable to edit feature layer from arcgis server
2058
04-26-2023 03:36 AM
BymiljøetatenOsloKommune
Hi I just wonder if anyone have same issue as me?
I add a FeatureService from my server into the new map viewer in agol, I cant edit (Add, update or delete).
I got this error messenger when do debugg in webbrowser: Error:
Combination of parameters rollbackOnFailure = false & returnServiceEditsOption = originalAndCurrentFeatures for applyEdits operation is not supported.
When I switch to classic map viewer work everything OK!
our arcgis server is current version: 10.81.
Thx for any help!
en update, the featureService is publish from arcgis pro is not working, But when I publish same from ArcMap its working!
jorisfrenkel
which version of ArcGIS Pro are you using?
im using the lastest arcgis pro version.
jorisfrenkel
It took a while longer!
I tested creating a feature service with ArcGIS Pro 3.1. I can edit the feature service in ArcGIS Online without problems.
Of course it's possible there has been an update in the meantime.
jorisfrenkel
Thanks, good to know, I will start testing the latest version in a few days, I will let you know what I find.
