Unable to disable feature layer delete protection in the settings
1844
01-31-2024 01:21 AM
LucianoLupedia
Hi guys,
I've enabled the delete protection setting as you can see in the second photo on a feature layer with more than 2 million features. Now, i can't even go to the settings because the layer just keeps loading, and it shows an error as seen in the first photo.
Is there any way I can disable the protection setting on the layer besides going to the settings on ArcGIS Online? I've tried doing so on ArcGIS Assistant by editng the JSON format, but the it won't update.
Thanks!
Ed_
by MVP Regular Contributor
For the error, hover your mouse over it and you will see a three dot icon, click on it and then click on assign ids automatically and that should resolve the error. Then try publishing again from ArcGIS Pro. Also for the warnings, you might want to look them up on Google. But you will still be able to publish in spite of the warnings.
Question | Analyze | Visualize
Ed_
Maybe try republishing the layer from Pro as republishing may help resolve this issue.
LucianoLupedia
I did it, but I got the following error instead even though there is an OBJECTID column:
Ed_
