Unable to add my layer
3750
13
05-28-2010 03:21 AM
nabaz-gharib
I add a layer package to may content but when I try to add it to the map the search show no result for my layer..
FawnaNibert
I am having the same problem  but on my end.  and now that ESRI as changed the web site I can not even see the basemaps on the creating a map.
MikeMinami
Esri Notable Contributor
Presently, you can only add map services as layers to web maps. We're working on supporting layer packages and "web enabling" them so that they can be added over a web map.
Fawna - Are you having trouble clicking the Basemap button on the toolbar of the Map? Can you provide more details?
Mike
davidraffenberg
Then put an asterisk or some note on the upload that these cannot be added yet.  I wasted time trying to do this.  I'll just go back to Google Maps.
nabaz-gharib
Mike
No I dont have a problem when I click on the Basemap button...my problem just I can't add layer package over a web map...
kenbates
I agree with the draffenb
Bernie Z...you said it was easy...just add stuff..i should have watched to see where all the content was coming from...
so why do we have an upload button ?....if all the content is coming from an ArcGIS server service?
if i were running ArcGIS Server full time i wouldn't need Arcgis.com?...
(next day update)...okay good nite's sleep i feel better...
so i guess the question is..."working on enabling layer packages "..
any time frame?...
MikeMinami
As far as a time frame, there is no definite time frame set yet. However, this functionality is not on our current release schedule, so that's an indication of where we are. There are some technical issues we need to solve before we can release this--mainly involved with connecting our back end systems.
Mike
NanAn
So...I guess I had the same question, but I want to make sure again. I added an layer package up to My Content, and I can really see that image. However, when I tried to create a map (a basemap with my image), I couldn't find my image and couldn't add it to make a map.
Mike, so this is what I can't do on ArcGIS.com right now, right?
Nan
MikeMinami
You understand correctly. You can't currently display your uploaded layer package on top of the ArcGIS.com viewer map...
thanks,
Mike
KenBates1
Painfully....
I betting there are a lot of users from the Conference who thought the same thing I did...
Go back, create local content and publish it via ArcGIS.com...
