Unable to add Geoserver WFS to ArcGIS Online
484
05-14-2025 02:33 AM
Labels (2)
JasnaAlmasi
Hello Community
I am attempting to add a WFS using this url - https://mhplanning.webgis1.com/geoserver/MhpData/ows?service=WFS
When doing so, I am met with an error message stating that the 'server does not exist or is inaccessible'. I have successfully added the service to ArcGIS Pro and QGIS and confirmed with AcuGIS that the CORS configuration on the Geoserver is correct.
Furthermore, confirmed that the data is accessible:
https://mhplanning.webgis1.com/geoserver/MhpData/wfs?request=GetCapabilities&service=WFS
Has anyone encountered this problem?
Thanks in advance.
Schalk
ZaraMatheson
Hello! When you connect to the layer in Pro, are you able to actually add layers? I don't see any available.  The message I see in Map Viewer is also slightly different: "The service is empty". I'll try again later and see if I can see the same issue you were seeing.
