Unable to Access Route URL
3363
6
01-23-2019 05:05 AM
NDA-GISGhana
Please I cannot access my route url when I am trying to add my directions widget in the webApp Builder. I need the solution very urgent. Below is the route url in the webApp builder: https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World
Thank you.
Tags (3)
RobertScheitlin__GISP
The directions widget has the url https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World by default in the Route Url. Are you saying that it will not give you the green check next to the url in the widgets dialog? Or are you talking about trying to access the url rest end point in your browser? If you attempt to access the url in your browser it will not work as esri has the rest end point disabled for browsing.
NDA-GISGhana
Thank you Robert, I am talking about the widget in the web appBuilder, it
would show red instead of green. This is short of it. Thanks.
Sulemana Suale
What errors do you see in your browsers console?
NDA-GISGhana
The error below is shown in the console:
ArcGIS REST Framework
Home <https://route.arcgis.com/arcgis/rest/services>
*Error: *Services Directory has been disabled.
*Code: *403
On Wed, Jan 23, 2019 at 2:19 PM Robert Scheitlin, GISP <[email protected]>
You should not see that error when using the widget. You would only see that error when trying to browse the url in your browser.
by Anonymous User
Not applicable
I'm having the same issues. Was this ever solved?
