Trying to chart related table and map won't save the right field to chart. It keeps changing to default field
2479
6
07-26-2017 08:52 AM
ScottFortman1
I am trying to add a chart with water quallity readings.  The readings are a related table to sample stations.  ArcGIS Online allows me to add the chart in the Configure Pop up window using the related table, but it keeps changing the field that I am trying to chart.  For example, I select "pH Readings" as the field to create the chart on in the settings but when I click ok and try the pop up, it charts the "Alkalinity" field instead (which is the first field alphabetically)
Is this a bug or am I missing something?
ScottFortman1
Matin,
As far as I know it is still an issue.  I did contact tech support and it is a known bug.  Unfortunately I didn't get a timeline as to when it would be addressed though.  One option I found that does work is to create a web app and use the Tables and Charts widget.  That one does work ok with related tables.
KellyGerrow
Esri Alum
HI Scott,
This sounds like a bug from your brief description. I'd suggest getting in contact with technical support so they can flesh this out further.
-Kelly
ScottFortman1
Ok I will do that, thanks Kelly.
MartinLewis
Scott,
Was this issue resolved?  I've just run into it myself.
ScottFortman1
Matin,
KellyGerrow
Esri Alum
HI,
Here is a link to the bug on the support page: BUG-000104430: Charts configured in ArcGIS Online pop-ups only resp..
Currently, the status is new. If you are running into the issue, contact technical support to be added to the bug. You will receive updates to the status changes of the bugs. Additionally you are able to escalate bugs if they are critical through My Esri How to Escalate a Defect | Support Services Blog
-Kelly
MartinLewis
Thanks for the update and pointer. I’ll check out the Tables and Charts widget.
Martin Lewis
GIS Supervisor
Bernalillo County
(505) 848-1579
Office365
