Token for Public Map Gallery
777
09-07-2012 06:12 AM
AndrewCullen
We're using the Public Map Gallery with ArcGIS Online, and have successfully deployed it and connected to group content using the ArcGIS Online Token Generator.
We requested a year long token, but the generated token (while working) shows that it will expire in two weeks from the generation date. (see attached screenshot)
Is there a problem with the generator, or are we using it incorrectly?
Andrew
MikeMinami
Esri Notable Contributor
For security, ArcGIS Online only allows obtaining two week tokens. The app has not been updated to reflect this.
Mike
AndrewCullen
Hi Mike,
Thanks for the prompt response. I see the inconsistency has been rectified on
http://www.esri.com/public-maps-gallery/token-tool/index.html
and only a 2 week token can now be selected.
Is there a recommended pattern for deploying the public-maps-gallery with private maps/groups? The standard configuration is to manually create a token to embed in the settings.required.js which is practical with a year long token, but less so if a new token is required fortnightly.
Thanks again,
Andrew
