Time-Aware Web Maps: Show features progressively settings not saving
281
11
a week ago
SaraJL
Hello everyone -
I'm curious if anyone else is having this problem! I have reached out to Tech Support, and they are still working on it.
If you create a time-ware Web Map - I've been encountering that if I set the timebar to "show features progressively" and the save the map and make it public, it will automatically revert back to time intervals instead of progressive. This shows up with both Chrome and Microsoft Edge.
I've managed to reproduce it with feature layers that I just created as well as data that I already had in the system that worked previously.
If it DOES work for some, please let me know - I'm trying not to freak out about it as I have 2 massive classes on Thursday that are creating time-aware maps and I usually need this function (if it doesn't work, I'll figure something out)
Thank you!
AJM
Yes here is the Experience ( which I referred to as the dashboard in the last post)
https://experience.arcgis.com/experience/6dcc5d61cea4482483dba6fc3a1f5f66/
and the webmap https://sccfgis.maps.arcgis.com/apps/mapviewer/index.html?webmap=1446fd59a3524ab0b093049f58f83de1
time22 is the time field.
TonghuiMing
Hi @AJM,
Thanks for providing the sample app. Even though I cannot access the layers in your web map, per our investigation, your case seems to be another topic - ExB does not yet support the "Playback Position" that you can configure and then take effect in MV. This is logged as one support ticket (ENH-000168985), and there are some related posts:
https://community.esri.com/t5/arcgis-experience-builder-questions/time-slider-playback-position/m-p/...
https://community.esri.com/t5/arcgis-experience-builder-ideas/feature-request-enhancements-for-timel...
https://community.esri.com/t5/arcgis-experience-builder-ideas/set-start-playback-position-in-timelin...
Let me know if it is not your case. Thanks for bringing this up.
