Tiled Service displays at incorrect scale, variable by scale of map, only in AGOnline
1420
6
05-18-2012 12:14 PM
DavidTreering
Adding two of my own services that display correctly everywhere else, even ArcGIS Explorer Online.  The Cached Tiled layer shows up at the wrong scale.  I can't figure it out.
http://bit.ly/KwgyWP
Any ideas?  I'm stumped.
David
MikeMinami
Esri Notable Contributor
I can't see your services in the map. Is your server publicly accessible? it seems not.
Mike
DavidTreering
http://147.126.65.155:8399/arcgis/rest/services/campus/lurec_base1/MapServer?f=jsapi
I cannot figure out why the service is not visible to you.  I can view it from anywhere on the web.  Port 8399 is open, unrestricted.
What should I try to make it available to you?
Thanks.
MikeMinami
I still can't access it. I don't know how to make it visible...
Mike
DavidTreering
I've tried opening it up.  Can you try again?
MikeMinami
Nope. I still can't access it.
Mike
DavidTreering
Stay tuned...the problem, finally discovered by Grant R. (who deserves a serious lollipop for Incident #1039390) is that I'm still using port 8399 for production deployment.  I left it as the default instead of changing it to the recommended port 80 or 443.
Apparently, there is internal ESRI use of 8399, so my traffic couldn't be seen by the tech support people (and only them), while people all over the place outside my network could see it fine.  That was baffling and frustrating.
Whew!  I'll get back to you when it is deployed on the correct port.
