Tile Packages Not Publishing
961
09-25-2013 06:50 AM
ParrBrian
Anyone having problems publishing tile packages? It's giving us very inconsistent results, and after quite a bit of testing, we're wondering if this is not so much a problem with our workflow, but rather a glitch in ArcGIS Online?
Cheers.
BP
RichardWatson
Can you provide detailed information with regards to what you are seeing?
Today, I saw some odd permission/resource errors.
Does your organization require the use of SSL?  I ask because there are several discussions where this causes problems:
http://forums.arcgis.com/threads/84282-You-do-not-have-permissions-to-use-this-resource-publishing
I have also seen problems with the UI when using the Chrome browser.
