Synchronizing feature service to File Geodatabase
3029
09-12-2013 11:15 AM
EricLink
Hello, I have a master dataset that is in a file geodatabase and from that master dataset I have created a hosted feature service in Arcgis online.  We are using the service within the arcgis app on a tablet to update agriculture field type changes while in the field.  My question is can I take the feature service data that has been updated and sync it with the file geodatabase in order to update our master dataset within the database?  Any info is greatly appreciated.  Thanks.
MikeMinami
Esri Notable Contributor
We are currently building this capability but it is not available now. You can, however, download as a shapefile currently or use the analysis tools to extract a file geodatabase, but the synchronization would have to be done manually.
Mike
EricLink
Thanks for your response.  I'll look forward to this update.
