The map viewer filter isn't working as expected for a number field with a domain
195
07-30-2025 08:40 PM
BrandonGuo
I have a small integer field "Approved", with domains "0" as "No", "1" as "Yes".
In map viewer, I created a filter "Approved" is not "Yes".
But the map also filtered out records where "Approved" is empty.
After applied the filter, records with empty "Approved" field also filtered out.
ChrisUnderwood
Hello @BrandonGuo , you might want to read BUG-000162236 to see if that helps with your understanding of what you are seeing.
https://support.esri.com/en-us/bug/the-is-not-operator-in-the-arcgis-online-map-viewer-fil-bug-00016...
ChrisUnderwood
BrandonGuo
Thanks, condition group solved the issue.
