Text in pop up
1341
02-11-2025 05:20 AM
Ainosez
I am setting up popups in Map viewer and have entered text with different attribute expressions. I would like that text to appear only when certain conditions are met and other text to appear if they are not met.
For example, if the risk field is “Low”, I don't want any text.
If the risk field is not low, I want all the expressions I have created to appear.
Any ideas? I am not familiar with this kind of language.
Thanks
KenBuja
MVP Esteemed Contributor
You can use Arcade to conditionally show text. Read through that blog and other articles (their links are at the bottom) about how to use it
Ainosez
Thanks,  KenBuja
I've consulted quite a few links but I can't achieve my goal, I'm new to programming.
For the moment I have solved the problem with this expression :
(when(($feature["NRTOTAL"]) > 0.2, TextFormatting.NewLine +'Los riesgo a considerar son:',($feature["NRTOTAL"] ) <0.2 , "", ""))
