TABLE
2454
9
01-30-2018 12:09 AM
tinigjeo
what can I do for add field  and column value ect ..on table
shan_sarkar
Tini,
You can refer Adding fields—Help | ArcGIS Desktop
I hope this helps!
~Shan
~Shan
shan_sarkar
Tini,
I hope this helps!
~Shan
~Shan
tinigjeo
THANK YOU BUT WHAT CAN I DO IF I WANT ADD VERTICAL COLUMN ?
IF YOU HAVE ONE EXAMPLE YOU CAN TELL
shan_sarkar
Vertical Columns are called Fields in a table and the Horizontal rows store the records in any table.
The link that I have shared is for adding the vertical columns.
~Shan
tinigjeo
I know this but my answer is for another this look
its more better with one example with video for help..
shan_sarkar
hg is the column name or the field name.
Column/Field:
Record:
I hope that clarifies the doubts.
~Shan
~Shan
tinigjeo
perfect
could you send me the video or the pdf material
shan_sarkar
tinigjeo
ok if you send me the video for my table its more better so you can help and understand and learn ..
shan_sarkar
For study materials I will highly recommend you to go through the following links:
What is geodata?—Help | ArcGIS Desktop
ArcMap | ArcGIS Desktop
https://www.esri.com/training/
~Shan
~Shan
