Syntax Error using Chrome to access sign in page
4830
06-10-2014 06:29 AM
GregYetman
With the latest version of Chrome (35.0.1916.114 m) I cannot access the sign in page at:
https://www.arcgis.com/home/signin.html
It loads as a blank page, even after a forced reload. From the console in Chrome, I can see this error:
cdn server url:  //cdn.arcgis.com/cdn/4177
Uncaught SyntaxError: Unexpected end of input base.js:1721
esri.arcgisonline.sharing.util.userPreferences base.js:1721
b.declare._loadFilterMode base.js:318
b.declare._finishStartup base.js:323
(anonymous function) base.js:321
(anonymous function) dojo.js:173
(anonymous function) dojo.js:148
esri.arcgisonline.sharing.geow.Account.getSelf base.js:2058
(anonymous function) dojo.js:172
Invalid 'X-Frame-Options' header encountered when loading 'https://www.arcgis.com/sharing/rest/oauth2/authorize?client_id=arcgisonline�?�display=iframe&parent=https://www.arcgis.com&expiration=20160&locale=en-us': 'ALLOW-FROM https://www.arcgis.com' is not a recognized directive. The header will be ignored.
Works fine in Firefox and IE 11.
Is this just me?
Greg
kaushivijay
Hi there, I'm facing the same issue. But in my case this is a bit random. It will work few times and then it will not work. Did you resolve this issue???
BenVan_Kesteren1
I have the exact same issue with Portal for ArcGIS when trying to log into our portal, IE and Firefox work, chrome loads menu but the sign in boxes do not appear.
NicolasGIS
Honored Contributor
Same for me.
Config:
 -  Chrome Version 73.0.3683.103 running on Windows 10
  - ArcGIS Enterprise 10.6.1
  - ArcGIS WebAdaptor 10.6.1
  - Windows Server 2016
