Sync an uploaded layer back with desktop Arcmap
783
05-08-2019 08:22 AM
AlanWheeler1
I have uploaded a layer onto the ArcGIS online and collected field data using the collector app. I now want to download or sync the data with my desktop version of Arcma. Is this possible and if so how do I do it? Thanks in advance for any responses.
Alan
Tags (1)
Katie_Clark
MVP Regular Contributor
Hi Alan,
In ArcGIS Online, you'll want to go to the item details page and export the updated layer to the data format of your choice.
Once this is downloaded to your device, you can pull it into ArcMap. You can then either just incorporate this updated layer into your map, or possibly use the Append tool to join it with the existing layer.
Would this achieve what you're hoping to do? Hope that helps!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
