Symbology base on multiple fields Coded Values
2316
06-04-2024 11:55 AM
Heberlyeng
I am trying to create an expression that will return all coded values from two fields (STATUS and Funding_Source) so that I can symbolize based on the results.
For example. if I have Status's coded values as:
A, B, C
and Funding_Source as:
X, Y, Z
I want symbology for:
A-X, A-Y, A-Z, B-X, B-Y, B-Z, C-X, C-Y, C-Z
If I use concatenate($feature.STATUS,'-',$feature.Funding_Source)
I only get values for populated fields not all coded values)
I tried building an arcade expression:
var STarray = Array(0)
var SD = Domain($feature, 'STATUS').codedValues
var FD = Domain($feature, 'Funding_Source').codedValues
for (var i = 0; i < Count(SD); i++) {
    for (var a = 0; a < Count(FD); a++) {
      Insert(STarray, 0, Concatenate(SD[i].code,'-',FD[a].code))
STarray
It returns an array of exactly what I want, but it makes 1 symbol with a legend value of the entire array output.
Is there a way to symbolize on two fields and get all coded values?
Thanks much,
JB
RhettZufelt
MVP Notable Contributor
In Map viewer symbology, click Expression:
I used:
var SD = DomainName($feature, "Status")
var FD = DomainName($feature, "Funding_Source")
return Concatenate(SD,'-',FD)
Which, since I already had several of the combinations in the data, it automatically sets up those class values.
Then, I added a new polygon "B-Y" since it wasn't already in the list, but it symbolizes by "Other".
Then, select the three dots and Add Value:
And enter the value(s) you want (here I add the missing "B-Y")
And it now symbolizes by the newly added value instead of "Other".
R_
RhettZufelt
I used:
R_
Heberlyeng
Thanks for the input.  This is what I pretty much ended up doing.  Just would be nice if this could happen without having to add the remainders manually.
Thanks again.
RhettZufelt
If I have to do this with many values, I find it easier to just create a features for each value off to the side before I create the symbology.
Once the symbology is created (and saved) you can delete the temp features.
R_
