Hi there,
I think this a simple issue, but I want to be sure about it. I have created a feature layer in my desktop (Pro 3.3) and then published it to ArcGIS ONLINE with sync enabled. I have used this layer to create serveal apps like Dasboards, Webmaps and Field Maps.
I would like to make some changes in the layer on my desktop (new columns, updated values in some columns) and then syncronize those changes to hosted version, but I don't want to lose any configuration I have in my apps (Forms, Symbology, Filters, etc).
Which is the best way to do this? Should I used 'Download Map' button on Pro and make all changes and then sync? Or I just need to do the changes and go to Share tab and 'Overwrite Web Layer'.
Thanks all!
You could do the latter, overwrite the feature layer, but you may be prohibited from doing so while Sync is enabled.
There is a third way! Just load the hosted feature in AGOL cloud in my ArcGIS Pro proyect and both are syncronized!
Thanks!
