Summary Widget is not working correctly, is it?
12032
19
10-19-2015 10:58 AM
PabloMangudo
I've tested on different Summaries component. One picture is a configurable app: Summary Viewer template (blue style layoute), it's work fine.
The other (orange layoute) is a Summary Widget under a web app builder (WAB), it's doubles or triples real results.
Both are working over the same map and the same layer. It is a feature layers from feature services, as Summary Widget documentation require but I can't get it work properly. I have tested in different WAB versión with same result (Arcgis Online, Arcgis for Developer 1.2 and Arcgis Portal 10.3.1).
Any ideas/suggestion to solve it?
DerekLaw
Esri Esteemed Contributor
Hi Pablo,
The inconsistency you are seeing between the Summary widget in Web AppBuilder Developer Edition v1.2 and the Summary application template in ArcGIS Online is a bug. Specifically, a bug in the Web AppBuilder Summary widget.
FYI, we've identified and fixed the Summary widget bug in the embedded Web AppBuilder in ArcGIS Online.
The bug fix will be included in the next Web AppBuilder Developer Edition release, v1.3. This will be likely available sometime in Dec 2015. The fix will also be included in the next Web AppBuilder embedded in Portal for ArcGIS in the 10.4 release, estimated release in Q1 of 2016.
Hope this helps,
DerekLaw
Hi Pablo,
Hope this helps,
PabloMangudo
Thanks Derek, I'll wait for those new releases.
TomGoeke
Does this bug fix also address the issue that the summary widget does not respect filters applied to a layer in the web map and also does not respect whether or not the layer being summarized is set visible in the layer selection (summarizes with layer on or off)?
DerekLaw
Hi Tom,
You've identified 2 separate issues that are not part of the bug described in the original post of this thread.
We have this listed as a future enhancement for the Summary widget.
Can you please contact Esri Tech Support and open an incident on this item with repro steps?
Hope this helps,
MichaelWainright1
Derek,
I have a question about this enhancement. Does not seem to be implemented at v2.9. Can you confirm if it has been implemented on the WebApp Builder developer side?
DerekLaw
Hi Michael,
According to the Web AppBuilder for ArcGIS Developer Edition v2.9 Issue Addressed List, the answer is yes.
From the document,
> BUG-000103872 The Info Summary widget in Web AppBuilder for ArcGIS does not reflect changes in the web map applied by the Filter widget when using ArcGIS Server web services.
If you're seeing an issue, please contact Esri Tech Support to investigate.
Hope this helps,
MichaelRobb
Honored Contributor
Hi Derek,
Do you perhaps have the Nimbus number reference for this bug handy?
Is the WABde 1.3 on target to be released before end of year?
Thanks!
DerekLaw
Hi Michael,
Q1) Do you perhaps have the Nimbus number reference for this bug handy?
A1) I believe the NIM bug # is 000089818 - Count Value displayed incorrectly while using the Summary Widget in Web AppBuilder.
Q2) Is the WAB developer edition 1.3 on target to be released before end of year?
A2) Yes. Web AppBuilder for ArcGIS Developer Edition v1.3 is currently undergoing final release certification testing. We anticipate its release sometime late next week or the Dec 14th week.
Hope this helps,
CHRISJONES10
Is the summary widget available in Portal. If so I don’t see it my choices.f
