Styles and Symbology using Arcade Expressions in Map Viewer Classic vs Map Viewer (new) with OR statement
1095
02-28-2022 08:50 AM
Labels (2)
DNVT
Hi All,
I am applying an Arcade Expression to style my feature layer in my web map. This Arcade Expression utilizes an AND (&&) and OR (||) statements. If I use the new ArcGIS Online Map Viewer, all label styles symbolize properly. If I use ArcGIS Online Map Viewer Classic, the label styles with the OR statements do not symbolize. Has anyone successfully used an OR statement in Map Viewer Classic?
Thanks!
jcarlson
Do you have an example expression? I've not run into this issue, personally.
- Josh Carlson
Kendall County GIS
