StoryTelling Swipe - Imagery.
641
11-11-2013 03:55 AM
El_BoukfaouiReda
Hi everyone,
I tried to work on a StoryTelling web template (Swipe) where I wanted to use 2 imagery files (.TIFF formats) to do the comparison.
Both images have been shared as Map Packages through ArcGIS Desktop.
1st map : http://www.arcgis.com/home/item.html?id=6e2e701333c74489ae0b4f0d59332488.
2nd map : http://www.arcgis.com/home/item.html?id=9b938cedeef44fe0b468a86549930384
Configuration:
webmaps: ["6e2e701333c74489ae0b4f0d59332488", "9b938cedeef44fe0b468a86549930384"]
After the configuration, I was not able to load both maps, I am getting the following error (attached document).
I don't know if it is due to the size of it or something else.
Please kindly help on that.
MikeMinami
Esri Notable Contributor
Unfortunately, map packages can't be displayed in web mapping applications. Only web maps can be used in the storytelling app.
Mike
