story map
2288
05-23-2017 04:39 PM
SheldonJessup
I do not know how to change the year format in Arcmap online. The data is properly formatted in Arcmap (desk top) however when the year is converted it is changing the format from a whole number to a two decimal integer. (see attached) How do i change this year format in arcmap online?
SJ
JayantaPoddar
The datatype of the field must have been Float or Double. You could follow the steps in How To: Change the number of decimal places displayed in a number field in an ArcGIS Online web map
You also need to uncheck 1000 separator.
In the Web-Map, go to the Sub-layer (Click the drop-down) > Configure Pop-up > Configure Attributes. Select the Field. Change the format. Uncheck "Use 1000 separator".
Think Location
JayantaPoddar
Think Location
SheldonJessup
OH My Goodness!!! thank you so much!
JayantaPoddar
Glad it helped!!!
Think Location
