Specify TimeZone for popups/attributes in arcgisonline maps
27763
34
04-08-2014 07:19 AM
AshakaThakore1
I have created a map on our arcgisonline account... It has layer which has some attributes of the date-type.... When I click on any point of that layer, it popups the window with attributes, now all the date-time values in that popup are displayed in PST(Or some other timezone).. How can I set it to display date-time values in timezone - EST?
How do I specify timezone in ArcGIS Online?
thanks
AshakaThakore1
Thanks mike, so the data in the database(Oracle) is stored as UTC and not as our local timezone time?
thanks
MikeMinami
Esri Notable Contributor
Where does your data live? Is it an ArcGIS Server service? Hosted in ArcGIS ONline? We assume data stored in ArcGIS Online is in UTC.
Mike
AshakaThakore1
I have a featureclass in Oracle 11g ArcSDE10.1...
I have published it in our external facing server which has arcgis-server 10
so my service is http://gisweb.wsscwater.com/ArcGIS/rest/services/WSSC/CustomerOutreach/MapServer
Then i created a webmap  using our ArcGIS Online account and i consume that service in that webmap...
That webmap http://wssc.maps.arcgis.com/home/webmap/viewer.html?webmap=f35adbe9b862471fb6842ae1f0fb1c40 shows wrong time.. It substracts 4 hours from all our date-time values
MikeMinami
Yes, this is the web browser shifting time from UTC. Are you 4 hours from UTC?
In ArcMap, you can set the timezone for a layer from the Layer Properties dialog, Time tab.
Mike
RoyceSimpson
This seems to correct the issue.  Thanks.
waelkatrou
Hello Mike,
I have a layer that has more than one date attribute (4 date attribute).
Is there a way to set the default timeZone for this attributes using ArcMap as you've suggested.
Thanx.
MikeMinami
Yes, in ArcMap, you can set the time zone for the layer through the Layer Properties dialog. The dates will still display with an offset in ArcGIS Online if you are not in the same timezone the data were collected in.
Mike
DownerNew_Zealand
I have the same problem as Wael. While your solution corrects our data for the one date field we specify in the time tab, not the other dates. We have multiple date fields in each record (5 to be exact). Is there any way to universally update the timezone for the entire layer, not just a single field? I've attached a screenshot that shows the discrepancy of the data from the database and how is displays in our Portal.Capture2.JPG
