Spatial filter in Experience Builder doesn't respond to selected polygon filter
2185
03-22-2023 09:49 AM
JanetSilb
I am applying a spatial filter to my query widget.  When I use "Geometries from a map" & draw a polygon, features from my data source are selected as expected. However, when I use "Selected features from data source" and choose any of my existing boundary polygon feature layers as the filter layer, and one of these 3 spatial relationship rules (Contain, Intersect, Within), the selected features do not correspond to the filter layer at all. Notice in image below the pink features fall outside the dotted line of the filter layer.
Omar_A
by Esri Contributor
It could be that the filter layer's spatial reference differs from your other layers' spatial reference. Another possibility could be a data issue with the layer itself, such as errors in geometry or attribute values. To troubleshoot this issue, I recommend checking the spatial reference of the filter layer and ensuring that it matches the spatial reference of your other layers. You may also want to check the integrity of the layer's data by reviewing the attribute table and checking for any errors or discrepancies.
StephanieSmith
Did you ever find a solution to this? I am having the same problem. It does not seem to be an issue of spatial reference like mentioned by Omar_A below.
Brad_Crowe_JR
I am having this problem has a solution been found?
