Smart Editor not allowing to add
923
05-11-2024 03:14 PM
LMBaptista
Hi, all.
I imported a shapefile to a feature hosted layer in AGOL and gave it edit permissions. Created the webmap with that layer. Used WebApp Builder to create an app with Smart Editor. All editing permissions were configured for the layer.
When I try to add new features with Smart Editor, when I press Ok I get this error:
"Cannot perform operation. Invalid operation parameters. 'adds' parameter is invalid. The specified geometry is not in the correct format. The given key was not present in the dictionary."
I have no clue what is this and the procedure I followed is the same as always.
Thanks in advance for any direction
LMBaptista
Hi.
The problem was the features was as multipoint instead of point. I had to split them and as points, it worked fine.
Laura
by MVP Regular Contributor
Can you edit in map viewer?
LMBaptista
Hi.
