Smart Editor Feature Labels
884
02-16-2020 07:09 PM
GlennDavidson
Smart Editor - templates:
Are there any tips to modifying the label that appears below a feature in the template page of the Smart Editor widget.
I have created Web Application that allows the user to add a point feature. The name of the feature is automatically set to "New Feature", however I'd like to change the label to be more descriptive of what the feature is.
AlixVezina
Hi Glenn Davidson,
Thank you for sharing your question.
The Smart Editor widget will display the templates as they were published with your service. Changes made to the symbology directly into the web map (including labels) may not be reflected in the template picker as you've described. This is a known limitation and a fix still under consideration in our product plan.
Regards,
Alix
