Show Related Records in ArcGIS Online Popup
13217
15
09-22-2014 08:20 AM
JakeMatthys
I have a 1 to M relationship class between a feature class and table.  I have published the feature class and related table to our organizations ArcServer and have created a web map using the map service.  I have configured the popup and it will show counts of the related records.  I have also added a chart of the related records in the popup.  My issue is with the 'Show Relate Records' link in the popup.  When clicking on the link, it shows the related table (with all rows, not just those related to the selected feature) in the split window below the map.  Ideally I would like the related table to be automatically filtered to show only those related rows that are associated with the feature that has been selected for the popup.  Is there anyway to link the map and the related table, so that selections in the map filter the related table?
- Jake
JakeMatthys
This bug appears to be resolved.  I have been able to view related data (with more that 30k records) in an AGO map.
Thanks ESRI...
- Jake
JillHalchin
Jake,
Even after the recent update to AGOL, I still can't get related tables to work right in the web map. It sees the fields, but they're blank.  Also, See Related Tables, opens the entire table, not just the related records.  I'm trying to figure out if there's something about the service that's causing this.  Are you using your own service or one hosted on AGOL? If it's on your server, is it 10.3?
Jill
JakeMatthys
Hi Jill,
I am publishing to our enterprise ArcServer (which is 10.3) and the data is being pulled from a 10.3 version of SDE.  Though I think the AGO show related records functionality was working correctly for me before I upgraded to 10.3.  I think the most important thing is that you have an established 'relationship class' in your geodatabase between your feature data and your related data.  Publish both the feature and related table to your server.  Consume them both in a a map, enable popups and when you click on a feature, you should get the show related records link.
This is the workflow that worked for me.
C_EHoward
I had it logged as a 'enhancement' as well but really it should be considered a bug/lapse in functionality rather than something that would be 'nice to have' as the term enhancement suggests.
As usual, I was encouraged to submit my request to the Ideas page.....my track record is not good for my ideas (I guess they all suck, ha) but if you want to promote this, maybe it will help
https://c.na9.visual.force.com/apex/ideaView?id=087E00000005H6GIAU
MelanieRosenberg2
Any update on this bug???? I followed the link and the tracker says it has not been resolved. This is an important issue to fix.
JillHalchin
Melanie,
The problem was fixed, last spring or summer, I believe. Related tables
pop open below the map.
Jill
Jill Halchin
Archeologist / GIS Coordinator
Southeast Archeological Center
National Park Service
Tallahassee FL 32310
850-580-8429
jill_halchin@nps.gov
Webpage: http://www.nps.gov/seac/
Facebook: https://www.facebook.com/NPSSEAC
Twitter: https://twitter.com/NPSSEAC
