Show Attachments from Related Table
928
11-01-2022 01:51 PM
michael_vetter
I've got a point layer that has a related table where picture attachments are stored. How would I include the attachments on the main point layer? Or is there a way to show the pictures in a popup for the table? I'm assuming Arcade is the best way to go about it.
Thanks in advance,
Michael
DuncanHornby
MVP Notable Contributor
If you are asking to see a photo instead of a point on your map then I would suggest that is not a sensible idea. If you want to see the photo in the pop-up when you click on the point then yes this can be done. You need to read the help file on configuring the pop-up, have a look at the images section.
michael_vetter
Thanks for the reply. I managed to somehow over look the show attachments option for the table.
