Hi Arc GIS Online community,
I am trying to map Canadian dissemination areas below, but I think the shape file coordinate system is NAD83/Statistics Canada Lambert Coordinate reference system and gives me the attached image.
I appreciate any help how to read it with Arc GIS online default WGS 1984 Web Mercator system. I only have GIS online and QGIS. Thanks
Thank you Russal. I downloaded the update file and it worked.
Looks like you are using the Digital Boundary version instead of the carto one. If you wanted to use that in the coordinate system. You could use this Gov Canada tile layer to have it in the same coordinate system
https://jsapi.maps.arcgis.com/home/item.html?id=3d0be59ed0fa4604b1b9384f9b9a8a36
