shaded relief USA map availability
748
11-07-2012 01:15 PM
ThomBryant
Is there a version of the Shaded Relief map that can be downloaded instead of using the web version?
SteveCole
Honored Contributor
Provided by ESRI? No- with one qualification. If you are under maintenance for any of the ArcGIS Desktop applications, you should also have the ESRI Data and Maps bundle of datasets which I believe includes a shaded relief image. These used to be provided as a set of DVDs but now is a download when you download your software.
Your best non-ESRI source for this information would be the USGS:  http://earthexplorer.usgs.gov/
You might also find additional data at your state or local level depending on your area of interest.
